View BGP Route Summary
Display BGP route summary.
  • To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  • The VRF must have an RP trigger of BGP.
  1. In the navigation pane, expand Configuration > IP.
  2. Select BGP.
  3. Select the Bgp Route Summary tab.
Bgp Route Summary Field Descriptions
Use the data in the following table to use the Bgp Route Summary tab.
Name
Description
Prefix
Configures the IP address of the route.
PrefixLen
Specifies the IP address and the mask length (the length can be 0–32).
LocalAddr
Specifies the local IP address of the entered BGP route.
RemoteAddr
Specifies the remote IP address of the entered BGP route.
